better gas milage
Old Jun 25, 2008 | 01:34 PM
KevinAccord's Avatar
Default RE: better gas milage
is it hard to replace the timing belt? i need to do it asap.
Old Jun 25, 2008 | 01:52 PM
Hardest thing is the crankshaft pulley. But thats another topic.
Old Jun 25, 2008 | 03:31 PM
finch13's Avatar
007, drop the 18 pounds of boost and I bet you'll see a jump in mileage.
Old Jun 25, 2008 | 06:00 PM
falkore24's Avatar
ORIGINAL: JimBlake
That took 5 seconds and no effort whatsoever with this.
Old Jun 25, 2008 | 06:05 PM
25/28/34 that sounds like a skinny gal with larger hips [&:]
Sorry Members, I couldn't resist that temptation: WheelBrokerAng
Old Jun 25, 2008 | 06:06 PM
falkore24's Avatar
ORIGINAL: WheelBrokerAng
Obviously not a boob guy!!! LMAO
Old Jun 25, 2008 | 10:45 PM
  #17
ford's Avatar
ORIGINAL: falkore24
lol!!=))ahahaha!!
to the OP, just as what finch said...drop that 18psi of boost and you'll see gains in your mpg..and also the way you drive...if you drive smooth...then like blake..youll see some more gains in mpg...
Old Jun 26, 2008 | 12:10 PM
  #18
Accord007
about adding more HP i figured because of the weight of these new accords a little bump in the HP area would be a good thing,also only after market part is a K&N replacement filter in my air box , should i return to an OEM honda filter? maintenace is up to date i do some work my self a i changed the spark plugs last year in advance , which helped with the mileage back then and HP, ALSO MEMBERS THE 18PSI BOOST IS FOR MY NISSAN 240SX NOT MY ACCORD, SORRY 4 THE MIX UP .
Old Jun 26, 2008 | 03:35 PM
  #19
falkore24's Avatar
K&N drop in filter is fine. No need to change back. What plugs did you use? Bosch kills Honda coils. They should be NGK or Denso. NGK double plat's are the best for Accords
Eroberto72
Jul 2, 2007 09:58 PM
thunder_x
Apr 24, 2007 10:25 PM
danjel
Apr 21, 2007 01:45 PM
thunder_x
Dec 15, 2005 11:44 PM
craiglawless
May 3, 2005 02:20 PM
