brake booster
Old Jul 22, 2011 | 10:54 PM
CD5Lover's Avatar
Default brake booster
i installd new dics and brakepad for some reason every time im going to stop my break pedal slowly moves down to the firewall i bleed the brakes still does the same but when the car is of the brake pedal get hard after a few pumps but when the car is on the break pedal loosens i pup the pedal but they go all the way down ? wat could be the problem
Old Jul 23, 2011 | 08:22 AM
Your symptoms are a leaking Master Cylinder (MC). New MC is an easy job, but you need flare tubing (10mm) to turn the tubing nuts w/o damaging (open end may damage).
I suggest an OEM MC for this critical assy and to minimize potential for need to adjust brake booster/master cylinder pushrod gap. You don't want to get into that adjustment.
Old Aug 6, 2011 | 07:08 PM
CD5Lover's Avatar
i have the car of i push the pedal the pedal slowly move down when the car is off
Old Aug 6, 2011 | 09:10 PM
Adler's Avatar
Pedal sinking in symptomatic of a faulty master cylinder as TexasHonda said. It could also be leaking lines, I hope for your sake that it is the master cylinder.
p.s.- Please work on your spelling and grammar, it is difficult to make out your questions.
austinman3214
Apr 29, 2018 07:32 PM
heathzx
Sep 20, 2010 12:04 PM
hondaptct
Aug 12, 2009 02:45 PM
status
Dec 28, 2008 10:30 PM
KGP
Jun 26, 2008 04:11 PM
