Brake problem - master cylinder or booster
Old Jun 25, 2008 | 11:11 AM
KGP
Default Brake problem - master cylinder or booster
1995 Accord. Occasionally, about a third of the time when I go to brake, the pedal sinks. Not all the way to the floor, but it steadily sinks. If I try to pump it up, it will just sink again. No leaking whatsoever. At first, I thought it was air in the lines. Bled them, and problem returned same day. Like I said, most of the time the brakes work just fine. Master cylinder or booster?
Old Jun 25, 2008 | 11:16 AM
Default RE: Brake problem - master cylinder or booster
Sounds like master cylinder to me.
Old Jun 25, 2008 | 11:41 AM
hondadude's Avatar
I would say the brake master is bypassing internally.
The most common description of the problem is "the brake pedal creeps down at stop lights"
FWIW; if the booster is losing vacum the brake pedal becomes stiff and harder to push.
Old Jun 25, 2008 | 11:46 AM
KGP
ORIGINAL: hondadude
Yep, that's a good description.
Old Jun 25, 2008 | 12:29 PM
Erinsaccord's Avatar
KGP: Just had that exact same problem with my 94 Accord and replaced the master cylinder with a rebuilt unit from NAPA. Now it's fine. Dave.
Old Jun 25, 2008 | 12:34 PM
KGP
ORIGINAL: Erinsaccord
Thanks Dave. Question: Did you bench bleed the master cyl when installing? I have a Haynes manual and it reccomends it...
Old Jun 25, 2008 | 12:43 PM
My description is the pedal sinks slowly & smoothly with NO leakage out.
I replaced MC on 95 Integra without bench-bleeding. I had to bleed A TON of fluid before finally getting all the stupid little air pockets out of the MC. So it IS possible, but...
Old Jun 25, 2008 | 04:21 PM
brayner's Avatar
bleed on the bench first, it's easy. You can just run two tubes back in to the reservoir and hand pump. You can get all the air out later, but bench bleeding saves time
Old Jun 25, 2008 | 04:57 PM
00AccordLX5spd's Avatar
Registered User
as has been said, it is the master Cylinder. I bought my replacement for my 95 from hondaautomotiveparts.com. Bench bleed it unless you want to waste a bunch of brake fluid when you have to bleed all the air out of the lines after it is installed.
Old Jun 26, 2008 | 04:11 PM
Yes, I bench bled it. I had to bleed a bit more air out once it was installed, but it only took a few cycles. Dave
hondaptct
Aug 12, 2009 02:45 PM
00AccordLX5spd
Aug 27, 2007 10:48 AM
deserthonda
May 27, 2006 02:58 PM
aso432
Oct 25, 2005 02:02 PM
aso432
Oct 23, 2005 10:41 PM
