A/C not blowing cold but compressor is running and free-on level is good??
Old Sep 3, 2008 | 12:58 PM
shad9876
Default A/C not blowing cold but compressor is running and free-on level is good??
A/C is not blowing cold in 95 Honda accord. The compressor is kicking on and the free-on level is good.
what could be the problem?
Old Sep 3, 2008 | 01:10 PM
falkore24's Avatar
Default RE: A/C not blowing cold but compressor is running and free-on level is good??
How do you know the freon level is good? Could be a blown expansion valve, but that's unlikely for an auto system. Most common is a leak resulting in no refrigerant.
FYI - Freon is a trade name given to R-11. It has been misused to refer to all refrigerants. Your car uses R-134a. Classics use R-12. Most houses use R-22. After I'm done with the Jacob Javits Center, it will have either R-407c or 410a ...... depending on how much equipment I can find in R-410a.
Old Sep 3, 2008 | 01:15 PM
shad9876
I checked the free-on level/pressure on the low port side with a gauge and it is reading in the full range.
Old Sep 3, 2008 | 01:59 PM
falkore24's Avatar
Compressor can be blown internally or the expansion valve could be blown or blocked.
Old Sep 3, 2008 | 03:39 PM
shad9876
anyways to test to see which it is?
Old Sep 3, 2008 | 04:45 PM
shad9876
Where is the expansion valve located?
Old Sep 3, 2008 | 04:50 PM
falkore24's Avatar
Not really without training. The expansion valve is on the high pressure side of the evaporator coil.
Old Sep 3, 2008 | 05:06 PM
deserthonda's Avatar
get both low side and high side pressure readings and post them here . that will give us a better idea of what is going on..
Sapowell84
Jul 16, 2013 03:18 PM
CFnt
Jun 2, 2013 09:59 AM
JangoFren
May 27, 2013 10:18 AM
BHoward711
Apr 12, 2010 08:57 PM
90accord90
Jan 25, 2010 03:28 PM
