cam gears
Old Nov 21, 2006 | 09:33 PM
poser_pilot6
Default RE: cam gears
Im not an expert by any means, but Im pretty sure that what they mean by porting and polishing the cylinder head is enlarging and smoothing out the ports so that everything flows better. Often this is done in conjunction with changing the pistons, maybe thats what you heard?
Old Nov 21, 2006 | 09:36 PM
sir_nasty's Avatar
Here's a good example of it with some pictures to give you a better idea of what a port and polish vavle job involves....
http://www.honda-performance.com/services-porting.asp
Old Nov 21, 2006 | 09:42 PM
02BlueAccord's Avatar
o thanks. yea pilot u mite be right on that one
Old Nov 22, 2006 | 01:36 AM
legionofone's Avatar
you balance pistons and rods
you knife edge your crank
you port and polish your intake and exhaust manifolds and and the valves and heads
Old Nov 22, 2006 | 02:15 AM
Great link there Mr. Nasty..went in there and got some learnin in that site: Thanks
Old Nov 22, 2006 | 12:43 PM
poser_pilot6
Okay, what does "balancing and blueprinting" an engine mean?
Old Nov 27, 2006 | 03:00 PM
  #17
ORIGINAL: poser_pilot6
Everything on the engine has some tolerances. Say the pistons have to weigh the same within 5 grams - you make them within 1 or 2. Make the diameter & straightness of the cylinder bore BETTER than Honda's allowable tolerance. And you do similar things to whatever other engine parts you can think of.
Old Nov 27, 2006 | 03:17 PM
  #18
poser_pilot6
Ah ha! The master comes through with the answer. Thank you, JimBlake, for edumacating me.
Betta285
Jun 13, 2007 11:08 PM
02BlueAccord
Jan 16, 2007 02:54 AM
02BlueAccord
Dec 19, 2006 06:19 AM
nygamble
May 1, 2006 07:51 PM
HondaLawgik
Apr 18, 2006 02:28 AM
