Camshaft Sensor type
Old Feb 17, 2018 | 08:32 PM
2009Honda's Avatar
Default Camshaft Sensor type
Hi all!
I am a 2009 Accord enthusiast who is trying to learn more about how the engine works. To be honest, I have research intentions which I can't divulge. Nonetheless, my current interest is learning more about the camshaft sensor. I see that the sensor itself is the Denso 196-2005. I can't seem to find what kind of sensor it is... (magnetic, Hall effect, optical, etc.). I even tried calling Denso, but they didn't answer back. The second question, what does the signal look like? Does the camshaft have a strange pattern wheel? And lastly, what does it look like in relation to the crankshaft signal? I have figured out what the crankshaft signal is all about, but need to know when the camshaft signal changes relative to the crankshaft top dead center signal.
Thank you,
Matt
Old Mar 14, 2018 | 08:38 AM
keep_hope_alive's Avatar
Cool question. I knew that at one point (when it needed replacing) but I don't recall.
techinfo.honda.com may give you the info you need. a one-day membership is reasonable given the wealth of information. A service manual will include test procedures to determine if the sensor is functioning properly.
Old Mar 14, 2018 | 11:06 AM
The cam "pulse plates" are shown in the picture at the opposite end as the sprockets. (#2 & 3 in the picture) The camshaft sensors poke towards those plates from that end of the head.
Since the pulse plates are inside the space where oil is flying around, I have a hard time believing the sensors would be optical. Magnetic vs. hall-effect I'm not sure how I'd find out...
Those plates are surprisingly inexpensive, like $10. But the sensors are pricey. I don't know if you buy those plates if you can tell what they're doing. I can't tell much from the parts drawing.
bossie
Mar 29, 2021 11:17 PM
snoopy4369
Feb 27, 2015 07:30 PM
godey
Jun 25, 2014 03:54 PM
kris_loehr
Dec 19, 2008 07:20 PM
