can anyone help?
hi guys, new member needing help!
my power steering cooling pipe has a hole in it and is leaking power steering fluid.
i went to Honda and there asking £141 for the part and trying to charge me £77 an hour for labour!! and saying it takes 2 hours.
wondering if anyone can help me get this part for cheaper as i could fit it myself or have an independent garage do it for me.
thanks in advance
thanks in advance
A good welding shop should be able to make a spot repair (soldering, brazing or splicing in a new section), if the problem.
This may not be possible of external corrosion has generally damaged the entire part.
Have you searched salvage yards for a replacement? Probably same part from many Accords and perhaps other Honda/Acura models.
yeah ive had a look around salvage/scrap yards, nothing as yet.
welding isnt an option as someone tried to use GunGum to cover the hole and as a result made it worse.
i saw a part on gumtree, howeve, it was for the 2002 2.2 diesel accord. do you think this would fit my car?
thanks
thanks
How big is the hole? Wear hole or corrosion??What year/trim Accord?
PS cooling loop is low pressure and moderate temps, so a layered J&B epoxy repair w/ ripstop nylon wrapped around and over the hole may work. First deposit a layer of j&b, then wrap w/ ripstop nylon (old umbreall is good source), the a final layer of J&B. For best results, remove the part, clean, and roughen w/ sandpaper before starting.
its a 2000 honda accord W reg (uk) 6th gen, 1.8i v-tec SE
the last person had already tried that. just thought a complete working part would be better and save time.
the whole part is corroded. it's the flow pipe that goes round the front of the car, just behind the front bumper.
thanks again
thanks again
Your options are new part, used part, or perhaps fabricate a part from steel tube. Used part has to be low cost option. Part should be same for all 98-02 Accords w/ 4-cyl. I saw that V6 Accord appears to have a different part.
You could temporarily bypass the cooling loop by splicing ends of rubber hoses together while waiting for a part. I wouldn't operate for an extended period and monitor PS fluid for signs of overheating. Heat load can't be much if a short loop of steel tube dissappated enough heat for worst case condition.
I have found that I had to go to the salvage yard to get help. Phone conversation always seem to fail when you are discussing an inexpensive part.
Ebay is an option in US, perhaps UK as well?
i'll get it fabricated, never thought of that. i actually know a guy that has his own fabrication business.
Thanks a lot for your help.
my car is 14 years old and this is the only thing wrong with her. she'll be running sweet in no time!!
thanks again J.
thanks again J.
Your Swindon-built car is different from the USA Accord, but that cooling loop should still be easy enough to make from some tubing. Cost saving is probably more than enough to buy a flaring kit so you can make the bubble-flare ends where the rubber hose is connected.
Try to use some kind of hose clamps in the same locations as the mounting brackets, so the tube doesn't get flapping around & break.
jfreakofkorn
Dec 7, 2013 08:33 PM
tunrdude16
Nov 27, 2007 12:54 PM
