car shake/vibrates when idle
Old Jul 6, 2017 | 11:43 AM
jay2509's Avatar
Default car shake/vibrates when idle
I drive 2007 honda accord ex. 2.4 L engine. My car is shaking for some 5 seconds, whenever I am at the stop signal and car is in D mode and AC turns on. I have showed it to 2 mechanics. They are saying it is because of mounts. Is it because of mount? If yes, do I need hydraulic mount or rubber is fine?
Old Jul 6, 2017 | 12:12 PM
shipo's Avatar
It's a pretty safe bet it's the mounts if two separate mechanics indicate that's the problem. As for what to replace them with, OEM mounts are the safest option.
Old Jul 6, 2017 | 03:32 PM
jay2509's Avatar
Any idea on using hydraulic mount or rubber mounts?
Old Jul 6, 2017 | 03:34 PM
shipo's Avatar
I'm pretty sure Honda put hydraulic mounts in there for a reason; I'd stay with those.
Old Jul 10, 2017 | 09:35 AM
Depends on which specific mount is bad, so match what's supposed to be there.
Honda likes to use vacuum-operated mounts too. They switch from soft to hard on command from the PCM. I hope the mechanics have checked whether it's a bad mount vs a broken wire or leaking vacuum hose??
miro066
May 28, 2013 03:39 PM
lebfire1476
Apr 27, 2011 06:05 PM
ksomesula
Apr 23, 2009 05:26 PM
ufosearch
Mar 15, 2009 09:54 AM
HondaAccordFan
Nov 15, 2007 05:09 PM
