car shake/vibrates when idle
I drive 2007 honda accord ex. 2.4 L engine. My car is shaking for some 5 seconds, whenever I am at the stop signal and car is in D mode and AC turns on. I have showed it to 2 mechanics. They are saying it is because of mounts. Is it because of mount? If yes, do I need hydraulic mount or rubber is fine?
Any idea on using hydraulic mount or rubber mounts?
Depends on which specific mount is bad, so match what's supposed to be there.
Honda likes to use vacuum-operated mounts too. They switch from soft to hard on command from the PCM. I hope the mechanics have checked whether it's a bad mount vs a broken wire or leaking vacuum hose??
ksomesula
Apr 23, 2009 05:26 PM
