Check engine light code on 91 accord
My check engine light is on . Im tring to read the code but im not sure how to read it my engine light flashes but just flashes it dont stop i understand that you should count the flashes but it dont pulse it just keep flashing
Try to find a manual for your car on this forum, and research for your symptom. Or take it to a parts store that read the codes for free - Auto Zone or the like - and see what they come up with, and post it back here.
The DIY section has a couple links to detailed instructions for reading the codes yourself. I don't know whether 91 falls into the older system (flashing LED on the ECU); or the newer system (jumper the SCS connector & watch the CEL flash).
Both systems I mentioned fall under OBD-1. No need for a "scanner" for OBD-1; just find which method (based on year) & read it.
78gaw
Jan 20, 2010 09:45 AM
bigant
Dec 2, 2008 04:10 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
