considering head swap...
Old Oct 10, 2007 | 02:14 PM
DJYoshaBYD
Default considering head swap...
I want to have vtec on my engine without doing a full engine swap.. I know you can bolt a vtec head up to a non vtec block... but for a 90-93 accord, what vtec head shall I use.. I dont want super high compression, simply because I am going to boost it...
so what vtec head should I get? and are the exhaust ports the same? cause I want to bolt my 90-93 turbo manifold to the new vtec head..
Old Oct 10, 2007 | 04:08 PM
00AccordLX5spd's Avatar
Registered User
Default RE: considering head swap...
If you want vtec you are going to need a new ecu also. I am not sure which vtec head would match to that engine. Maybe an f22b1?
Old Oct 10, 2007 | 11:46 PM
Velocifero's Avatar
ORIGINAL: 00AccordLX5spd
whatever youre gonna spend even if this works wont be worth the small amount of hp you would get from it. not very helpful to your question i guess..or was i...
Old Oct 11, 2007 | 12:23 AM
Shadow1992's Avatar
The most direct bolt-up would be the H23 head. All F and H engines (with the exception of the F20 from an S2000) are interchangable with varying degrees of modification. BUt the H23 is the most direct fit on the F22A if you just want DOHC. The H22A head also bolts up very nicely.
Old Oct 11, 2007 | 01:24 AM
02BlueAccord's Avatar
i have a f23 on my 02 accord so i would be able to put up a h22 or h23 head on it? and whay would it do as of power if any?
Old Oct 11, 2007 | 07:19 AM
falkore24's Avatar
the H head is better for NA, the F head is better for boost or nitrous
Old Oct 11, 2007 | 08:41 AM
Registered User
ORIGINAL: 02BlueAccord
You would be able to do this. They call it a "G23." Do a google search or go check out www.6thgenaccord.com. That's where I found out about it. I searched on there and I think I found a link to a G23 build from another forum. It's been a while back so I can't remember for sure. The G23 is either a combo of an F23 block with h22 head or an F23 block with h23 head....I can't remember which.
If you swap an h22 head on there, you would be able to use many of the h22 mods (more available than for f23)
Old Oct 11, 2007 | 10:28 AM
oh ok thanks. would i have to replace my headers and intake as well? or would they fit
Old Oct 11, 2007 | 10:50 AM
Registered User
I imagine you would have to replace. The intake might fit.
Old Oct 11, 2007 | 03:43 PM
oh ok thanks.
honda007
Sep 12, 2007 07:46 PM
dlr213
Apr 3, 2007 02:15 AM
Storminnorman03
Dec 27, 2006 09:27 PM
BoBoish
Sep 9, 2006 10:34 AM
mwr
Aug 30, 2006 12:57 AM
