converting engine
Old Dec 5, 2011 | 11:31 PM
Eazysc's Avatar
Default converting engine
I have a obd2a 96 honda accord f22b2 non vtec engine and im trying to convert it to a obd1 so i can get around the crank sensor which is preventing it from starting I have a 94 accord chassis im tryin to put it into what all will I need to convert this obd2 engine to work in a obd1 body.
Old Dec 6, 2011 | 07:47 AM
g22cd5's Avatar
Supper Moderator
you need a obd2 to obd1 conversion harness.
Old Dec 7, 2011 | 09:12 AM
g22cd5's Avatar
Supper Moderator
also I believe you will need to use your obd1 f22b2 injectors. ALso after thinking about it you will need to use your obd1 dizzy too. Unless you buy the jumper harness for the dizzy. I know you can buy one from passwordjdm.com for like $35
Crazyguy
Jul 5, 2010 08:31 AM
Antarctica
Oct 15, 2007 11:00 PM
kaotikcariz
Aug 6, 2007 08:06 PM
honda212
Dec 11, 2006 01:36 AM
1a9c9c9ord
Nov 28, 2006 10:28 PM
