Coolant Leak
Old Apr 12, 2017 | 10:02 PM
HondaOwner20's Avatar
Default Coolant Leak
Hello. Thanks for reading my post. So, about 2 weeks ago, a family member stated that they smelled coolant in my garage where my 2007 Honda Accord was parked. I shrugged it off because I didn't smell anything. Last week on my way home from work, my heat wasn't blowing hot air, but then resolved itself before I got home...so, cool. Two mornings later, I am sitting in my car idling and the thermostat is reading hot. I turned it off, let it cool down and then booked it home keeping a close eye on the thermostat to ensure it didn't get too hot. Added coolant mix. Seemed fine. Checked the coolant a day later, noticed it was low and added more, as well as noticing the rad cap was broken. I replaced that today hoping it would be the fix. This evening I went to check it out and observed a drip from just in front of the catalytic converter. Please, suggestions would help. Any chance that this is a hose issue or is this my personal nightmare as funds are low and I am no mechanic?
Old Apr 14, 2017 | 06:25 PM
Since you don't repair yourself, you need help to find the fault and remedy.
Problem suggests a pressurized leak test is necessary to locate leak, leading to repair.
Old Apr 18, 2017 | 07:26 PM
Thanks for your response. It actually turned out to be the heater control valve with a pretty visible leak. A $40 part and a gallon of antifreeze later and I'm back in business. Thanks!
cengland84
Dec 25, 2008 11:18 AM
tr7driver
Dec 1, 2008 12:00 PM
shep03
Oct 16, 2008 10:08 AM
vlil
Jul 29, 2008 10:53 PM
vmac1
Jul 3, 2007 08:06 PM
