Cylinder Head
Old Oct 1, 2009 | 04:40 PM
Texas4Banger09's Avatar
Default Cylinder Head
I've got an F22B2... Could I replace mine with a H22x cylinder head? I'm not 100% sure how it works but I know the displacement must be the same. Do the number of overhead cams have to be the same... I have SOHC and the H engines are DOHC or could I in some way convert to DOHC by buying 2 camshafts and installing a H22x cylinder head?
________
Buy E Cigarette
Old Oct 2, 2009 | 07:46 AM
Yes you can put on a H22x head. I don't know the details of which ones are compatible, or what all you have to do. Search for "G-series" or "G-22" because that's a common slang for that combination of F-block with H-head. Also called a frankenstein.
You'll need lots of stuff. Probably an ECU from an H-engine, some wiring harness mods, etc.
Old Oct 2, 2009 | 08:45 AM
Also need H22 crank pully, H22 timing belt, intake and exhaust manifold and possibly even some machining work. All in all you wont make that much more power, and probably be cheaper to just buy an H22.
Old Oct 2, 2009 | 12:44 PM
nponer's Avatar
+1
H22a all the way
Old Oct 2, 2009 | 02:01 PM
so forget going N/A and just turbo it?
________
GoldenBlond
Chris Jameson
Feb 19, 2013 06:39 AM
82009_honda
Nov 26, 2009 09:17 AM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
Drpepper
Jun 4, 2007 11:17 AM
