Engine "chip"
Old Mar 10, 2006 | 06:13 PM
Dr.Evil's Avatar
Default Engine "chip"
I keep hearing about a mysterious "chip" that opens up the engine perfomence.Yet no one can tell where of how I can get it. I have the 03 V-6 coupe and there are few upgrades available. AEM has nothing in the EMUs' for my year. Is this "chip" an automotve "spanish fly"?
Old Mar 10, 2006 | 11:08 PM
marbro's Avatar
Default RE: Engine "chip"
The only real chipping with newer cars requires solder work and a chip burner. Otherwise you have to replace the ECU to get any gains that way. But you cant really expect much out of a stock engine but by changing the ECU. There are also air fuel controllers which alter the sensors to change the fuel map. Not many vehicles get 20 to 30 hp just from chipping a stock car. It usually requires increase intake exaust flow, increased bore/stroke, turbo setup, things like that. You could increase the amount of fuel that goes in but if its not fully burned its being wasted and that doesnt promise you will get a benefit from from that.
Old Mar 11, 2006 | 12:08 AM
Dr.Evil's Avatar
I've already done the cold air, catback and throttlebody. I'm thinking about bigger fuel injectors, but that would need some sort of piggyback onto the ECU to be able to use all that fuel. Peformance Accord does have cams (regrinds) and prepped heads, but I don't want to go that far, I still need a daily driver. Any suggestions as far as "simple" bolt ons?
Old Mar 11, 2006 | 12:22 AM
mbo1985's Avatar
I don't think you'll see to much of a difference with injectors. I would consider doing your ignition system before the injectors (which should be fine on an N/A motor). You'll probably notice that more and it should be around the same price.
Old Mar 11, 2006 | 12:27 AM
marbro's Avatar
if you increased the throttle body size and didnt bore out the plenium / whole intake manifold you have kind of a unused mod there. Because the stock throttle body is the exact same size of the plenium entrance.
eurotuner
Jul 25, 2010 07:58 PM
liquidhalcyon
Jan 7, 2008 03:21 PM
4drwithspeed
May 20, 2005 05:18 PM
Evlampius
May 4, 2005 02:49 AM
Apr 14, 2005 10:05 PM
