engine damper
You mount it on the engine and somewhere on the engine bay to stop the engine from torquing int he mounts when you give it gas.... Its basically the cheaper, less effective way of getting solid engine mounts.
The polys do a lot more than the ETD when you compare one to the other. On my car, we did the mounts and played with it for a while to see where the additional support was needed and in what direction. Then the ETD mount was custom made to improve the effect of the poly. I never actually drove the car with just poly ..... it all went on the same day.
