engine damper
Old Dec 12, 2008 | 01:09 PM
baconsum1's Avatar
Default engine damper
whats up guys! WHATS the deal with an engine damper kit? what is it what does it do and is it a wise purchase for my 2000 4 cyl accord coupe?
Old Dec 12, 2008 | 01:11 PM
finch13's Avatar
Default RE: engine damper
You mount it on the engine and somewhere on the engine bay to stop the engine from torquing int he mounts when you give it gas.... Its basically the cheaper, less effective way of getting solid engine mounts.
Old Dec 12, 2008 | 01:12 PM
It aims at stopping wheel hop, which is the motor moving back and forth under load. It isnt really needed unless you spend alot of time at the drag strip.
Old Dec 12, 2008 | 01:14 PM
baconsum1's Avatar
u guys are are da bomb quick fire question answering.. thanks alot!
Old Dec 12, 2008 | 01:15 PM
Finch I have "solid" motor mounts and still get dumb amounts of wheel hop at the track, maybe i should get one of these.
Old Dec 12, 2008 | 01:17 PM
falkore24's Avatar
ETD isn't only for track use. Mine is custom mounted in addition to poly mounts and I can spin without wheel hop whenever I want to take a few miles off of my tires
Old Dec 12, 2008 | 01:23 PM
baconsum1's Avatar
i think i might roll with the poly mounts first then try out the etd. how much chang$$ on the poly's?
Old Dec 12, 2008 | 02:22 PM
falkore24's Avatar
The polys do a lot more than the ETD when you compare one to the other. On my car, we did the mounts and played with it for a while to see where the additional support was needed and in what direction. Then the ETD mount was custom made to improve the effect of the poly. I never actually drove the car with just poly ..... it all went on the same day.
Swinnyp
Sep 6, 2012 05:53 AM
honda97acc
Jun 15, 2008 03:29 PM
ziwang55
Jun 4, 2008 12:22 PM
falkore24
Oct 23, 2007 11:28 AM
tsblckcord
Feb 22, 2006 07:07 PM
