engine help
Old May 13, 2008 | 11:11 AM
ghettoluxury
Default engine help
I have a 94 accord ex with the vtec engine but it's blown, so my question is will the ecu run a non vtec motor from a 93 if I use the vtec intake or will i have to use the intake from the 93 and get a new ecu
Old May 13, 2008 | 11:39 AM
finch13's Avatar
Default RE: engine help
I very highly doubt an ECU from a 5th gen will run a 4th gen engine. Go buy yourself the correct ECu for the engine at a junkyard, expect to lay down $100.
Old May 13, 2008 | 11:52 AM
00AccordLX5spd's Avatar
Registered User
I highly doubt it as well. Why not buy another 2.2 VTEC? You should be able to find a fairly low mileage one for dirt cheap from a salvage yard
Old May 13, 2008 | 01:48 PM
KevinAccord's Avatar
I agree w/ finch and Jon, it won't work, and it would be better to either get an ECU at a local junkyard or a new engine... depends on your budget i guess... If you decide to get the engine, why not upgrade it while it's out? many of us who have taken out our engines for some reason and haven't touched them internally regret it... (im one[&o])
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
blahblah
Mar 18, 2007 02:33 PM
hopkinted
Dec 30, 2006 04:41 PM
Brendo613
Feb 23, 2006 07:26 PM
