F22B Model Engine DOHC Non-Vtec
Old Aug 10, 2008 | 01:02 AM
sofireguy's Avatar
Default F22B Model Engine DOHC Non-Vtec
Ive been talking to some around town Gurus and they say its the way to go if I wanna swap. They were saying everything will bolt up and I can use all my old electrical and ECU even. And since it is a DOHC its going to have a higher compression ratio. And that it can take a considerable amount of boost. What do you guys think? Judging i can get from any JDM site for about 800 shipped and thats with 25-35 thousand on the engine. Just think if i try to find one local.
Old Aug 10, 2008 | 01:07 AM
Default RE: F22B Model Engine DOHC Non-Vtec
h22 will use most of the same stuff except ecu and make alot more power
having 2 cams doesnt make the compression higher
Old Aug 10, 2008 | 01:08 AM
the 25-35k that the importers say is complete BS they have no idea how many miles are on the motor
high compression + boost = bad idea
Old Aug 10, 2008 | 09:22 AM
sofireguy's Avatar
Well its actually going in a 94 Accord Ex. Well if it has less than 200k on it and it runs, then im ok with that. You have to make the proper preperations when putting any forced induction on a motor (>.&lt. Meaning lowering the compression, upping the fuel consumption, and possibly upgrading on your fire. But Im sure you knew that. Just letting you know that Im not going to throw 15psi on a stock motor so i can blow a headgasket or throw a rod. <- When I crank it. lol
Old Aug 10, 2008 | 10:10 AM
BlkCurrantKord's Avatar
It has a lower compression ratio, not a higher one. Boost that motor, it can take it.
Old Aug 10, 2008 | 11:13 AM
03Sleeper's Avatar
DOHC don't necessarily have a higher compression ratio.
03Sleeper's Avatar
Take the K24A4 vs. the J32A3. The K24A4 is 9.7, while the J32 runs between 10.5-11. J32 is SOHC, K24 is DOHC.
Old Aug 14, 2008 | 05:44 PM
bochincheboy
QUESTION: i'M ALSO DROPPING A F22B INTO MY 91 ACCORD 2 DR EX HOW SHOULD I WIRE UP THE VACCUM LINES CAUSE THE INTAKE IS DIFFERENT THAN MY F22A. AND ALSO THE F22B HAS A SEPERATE VUCCUM BOX UNDER THE INTAKE I ELIMINATED THIS WILL IT CAUSE ANY PROBLEMS ANY HELP WILL BE MUCH APPRECIATED THANK YOU
cd51994accord
Jan 30, 2014 12:56 PM
redbull622
Oct 23, 2009 05:06 PM
crensign
May 14, 2009 05:25 PM
PTVDesign
Oct 28, 2008 09:20 PM
wjmj
Jan 7, 2007 10:57 AM
