f22b1 compression test
Old Sep 6, 2010 | 06:33 AM
hydrastas's Avatar
Default f22b1 compression test
cyl1=70 cyl2=140 cyl3=65 cyl4=140
Wondering if it's normal for cylinders to go out in this order or not? I havn't lost any oil since i've had the car so im thinking it's just all blowby on the piston rings. Could the rings of vibrated towards each others gaps? Perhaps if i considered the firing order it'd make more sense. How much power could i expect to lose from having this compression?
Old Sep 6, 2010 | 08:53 AM
g22cd5's Avatar
Supper Moderator
cyl 1 and 3 are really low. Sounds like you need a new hone..but your rings could be bad too.
You are prob. running around on 100-120hp most likely
Old Sep 13, 2010 | 06:50 PM
g22cd5's Avatar
Supper Moderator
ok just looked at all data and it says....
COMPRESSION PRESSURE SPECIFICATIONS [1]:
Nominal 1250 kPa (178 psi)Minimum 950 kPa (135 psi)Max. Variation 200 kPa (28 psi)[1] At 250 rpm and wide open throttle.
Old Sep 13, 2010 | 09:00 PM
g22cd5's Avatar
Supper Moderator
BTW thats a dry test NOT wet test
Old Sep 17, 2010 | 12:49 PM
Velocifero's Avatar
Compression isn't as important as the consistency. I'd be more worried about that.
jkrueger2020
Jun 25, 2012 10:39 PM
Dshow
Dec 6, 2009 03:38 PM
importedminds
14
Jun 30, 2008 10:14 AM
eric123
Mar 21, 2008 11:57 PM
curious126
Apr 17, 2007 02:22 PM
