f22b1 main bearings
Old May 25, 2013 | 09:37 AM
treyschls's Avatar
Default f22b1 main bearings
muy f22b1 vtec engine has 22222 stamp on crank and ccbcc stamped on block which comes out to y/g,y/g,y,y/g,y/g. (that's yellow and green.)
with yellows in the block and greens as well..(I know it meant one half yellow one half green, but I wanted to see the difference in the bearings...)the yellow had a clearance of .0020, which is the service limit for journals 1,2,3 & 4...
here are muy books' readings
-oil clearances-
# 1 &4 standard .0005-.0015 service-.002
# 2 standard .0008-.0018 service-.002
# 3 standard .0010-.0019 service-.0022
# 5 standard .0004-.0013 service-.0016
I also tested browns and acl bearings.
these are the clearances I got with a dial bore gauge.....
green bearings- .0019
yellow bearings- .0020
brown bearings- .0015
acl bearings- .0025
any ideas
Old May 25, 2013 | 01:31 PM
treyschls's Avatar
what should I go with? the stamps on the the crank and block are keep the clearances in spec with different bearings..
treyschls
May 25, 2013 02:30 PM
elmerochingon
Oct 25, 2012 10:21 PM
panamared
Apr 6, 2007 02:08 PM
BigMike
Oct 21, 2006 11:31 PM
Mar 9, 2006 05:59 PM
