f22b2 bent rod.. next step
Old Mar 10, 2013 | 10:45 AM
christopherlee's Avatar
Default f22b2 bent rod.. next step
so i have a bent rod and was planning on doing a h22 swap
but sadly im only 900$ cash in pocket and the junk yards currently dont have one.
i want to run vtec but i also have to remember my budget
any ideas or helpful tips?
js, im in missouri and doing all the labor myself.
would a f23a1 head swap work? just to get it running till i can afford a whole swap?
Old Mar 10, 2013 | 01:44 PM
Did you move?.....your IP address is CA?
Anyway, try "car-part dot com" and search for engines in your area. Just remember are some things you'll want/need to replace during the swap.....so if you can get an engine in the four to five range,,,,the rest will go for those - timing belt, wp, rear main, misc hoses, fluids, ect....
Old Mar 11, 2013 | 03:18 PM
hondacars94's Avatar
swapping heads would get you by for time being, but make sure u get everything from donor car that you would need, power you want still wouldnt be there like the h22
Old Mar 12, 2013 | 06:02 PM
Ah, just me but if a connecting rod is bent.....a head swap is not going to do anything for the OP? Or were you going somewhere else?
Will_V
Mar 5, 2020 11:55 PM
Restless
Jun 4, 2013 12:09 PM
g22cd5
Sep 27, 2011 08:57 AM
maro
Aug 1, 2008 10:06 AM
