F23 swap in Gen 5
Old Nov 16, 2012 | 08:13 PM
Cody_754's Avatar
Almost A Senior Member
1997 Honda Accord SE with a JDM F23 VTEC swap. Running the P0H-L51 ecu. Engine seems to lose all power at about 4500 then acts like there's a rev limiter at 5500. No CELs! VTEC is not engaging I don't think. Any thoughts?
Old Nov 17, 2012 | 08:21 AM
Cody_754's Avatar
Bump.
Old Nov 17, 2012 | 08:55 AM
RobinsonRicer's Avatar
My moms car had an issue kinda like that at high speeds. I cant remember exactly what it was though. I think something as simple as a spark plug or something. Try going through the ignition system. If its swapped id check the ECU too, you may have a bad chip or ecu
This should also be in its own thread.
Old Nov 17, 2012 | 01:15 PM
Cody_754's Avatar
Old Nov 17, 2012 | 04:02 PM
Roader's Avatar
It does sound like the VTEC's not kicking in. Your ECU should have only one wire for the VTEC; for the solenoid. Download a factory service manual if you don't have one and troubleshoot. It's pretty easy as long as you have a DVM.
Old Nov 17, 2012 | 04:14 PM
Good advice on the factory service manual..I belive you might be able to find more on this in the search function of the forum..
Old Feb 5, 2013 | 09:54 AM
  #17
jorgelm86's Avatar
Need help my car is a 94 accord lx i did the same swap from a f22 non vtec to the f23a vtec i use the f22 harness and ecu when i started the f23 the rpm goes up and down it hits up to 4000rpm how can i fix that problem..
Old Feb 5, 2013 | 03:03 PM
  #18
Roader's Avatar
Which IACV are you using, two-wire from the F22 or three-wire from the F23?
Old Feb 5, 2013 | 11:52 PM
  #19
jorgelm86's Avatar
Im using the 2 wire from the f22 because i put the f22 manifold
Old Feb 6, 2013 | 08:33 AM
  #20
Roader's Avatar
Your B2 manifold doesn't have fuel injection air (FIA) but the F23 cylinder head does. Since you're using a manifold without FIA on a head with FIA, is it possible that the F23 cylinder head has FIA holes that are open to atmosphere, creating a giant vacuum leak?
IDK for sure because I kept the F23 manifold on the F23 engine. Some pics of FIA manifold/head/gaskets here:
honda-tech(dot)com/showthread.php?t=2284816
