F23 swap in Gen 5
Old Feb 6, 2013 | 10:03 AM
  #21
jorgelm86's Avatar
This is my first engine swap that im making thats why im asking to many ? do you recomen me putting the f23 manifold i have it
Old Feb 7, 2013 | 10:40 AM
  #22
MonopolyMan's Avatar
I ran an F22B manifold on my F23 swap, worked like a dream.
Old Feb 7, 2013 | 11:01 AM
  #23
jorgelm86's Avatar
Any idea on how i can solve my idle problem change the iacv but still keeps going up qnd down
Old Feb 7, 2013 | 01:55 PM
  #24
hgbassman1220's Avatar
Default help with IAC valve wires
Is there a way to wire a 2 prong connector from a 96 in to the IAC Valve on the 98 three prong female?
Old Feb 9, 2013 | 08:49 AM
  #25
Roader's Avatar
Not to my knowledge. Even if you could wire it somehow, the OBD2a ECU couldn't operate the 3-wire IACV.
Old Apr 30, 2013 | 05:40 AM
  #26
jorgelm86's Avatar
So i did the f23 vtech swap on my 94 accord lx 5 speed non vtech i used the f22 harnnes and manifold it was running ok untill 3 days my cel turn on i got the code and it gives me code 4... Now i know i need to change the ecu dont know wat ecu to get from wat car and when i change the ecu will mu cel go away someone help pls
Old May 1, 2013 | 09:47 AM
  #27
Roader's Avatar
I don't have any experience swapping an F23 into an OBD1 car but I have a few questions:
  • What distributor and coil are you using, the ones from the F22?
  • What ECU are you using, the original one from your car or a different one?
  • Did you wire up the VTEC solenoid valve and VTEC oil pressure switch?
  • Other than the CEL code 4, is the car running OK?
Old May 1, 2013 | 10:34 AM
  #28
I used a chipped P28 ECU (I used to chip them and tune them myself). Then I just ran a stock map for an F23 with slight tweaks. Ran super strong with no problems.
I guess I never realized how fortunate I was with how strong it ran. Now I'm seeing everyone's having problems with the swap and it makes me wish I still had my car lol
Old May 1, 2013 | 05:31 PM
  #29
jorgelm86's Avatar
Im using the same distributor and coild offthre f22... I still have on the same ecu that was with the f22 and no i didn not wire the vtech i have not done it dont know how to do it and because i wanted to change the ecu first... and when the code 4 appear i felt it kind off lags it on some gears
Old May 1, 2013 | 05:46 PM
  #30
jorgelm86's Avatar
From wat car could i get the ecu and how could i do the tune it and wire it
