Fuel injection cleaning help
Old Feb 6, 2006 | 02:24 PM
Jeff247's Avatar
Default Fuel injection cleaning help
I have a 2003 Accord 4 cyl 2.4 L with 105K miles. I had the oiled changed and the guy at Jiffy lube said I needed my fuel injection cleaned. What's the best approach for cleaning? He pulled the hose to the "injector rail" and said he saw carbon build up. I beleve the "injector rail" is the hose that travels above the cylinders and feeds each injector. Does that sound right? Thank you for the help.
Old Feb 6, 2006 | 05:36 PM
98accrd's Avatar
Default RE: Fuel injection cleaning help
Sounds like a load of bull to me. Jiffy Lube is notorious for screwing people out of money by selling services that are not needed.
Old Feb 6, 2006 | 06:01 PM
RTexasF's Avatar
Super Member
ORIGINAL: 98accrd
^ My first impression is the same. Is the car running well, smooth idle, good mileage? If so a dose of Chevron's Techron (large bottle for 20 gallons) every 3-5 K should keep it that way. Bottle into tank 1st then fillerup!
Old Feb 6, 2006 | 08:09 PM
7thGen's Avatar
Be very carefull with Jiffylube. Honda does not recommend running injector cleaner. I find it odd that they would say that there was carbon on the hose to the fuel rail. Only gasoline runs through there, so if there was carbon in there it would mean your fuel was burning before the injectors. The only problem we see at dealership is the electronic part of the injector sticking. Not in Accords newer than 94 yet.
Old Feb 6, 2006 | 08:30 PM
Jeff247's Avatar
ORIGINAL: 7thGen
Thanks for the advice. Do you agree with injection cleaner in the gas tank?
Old Feb 6, 2006 | 09:00 PM
lightshow's Avatar
yes lucas make a very good injector cleaner for about 3 bucks but anything with a 4-8 percent jet fuel will be just fine. you will never have any carbon buildup in your fuel rail.....ever....thats like someone telling you that you need a muffler bearing.
lightshow
PAhonda
May 17, 2024 03:53 PM
d_10
Sep 19, 2007 07:11 PM
Draco
Oct 4, 2006 09:22 AM
thunder_x
Jul 29, 2006 09:11 PM
nrangerfan
May 19, 2005 12:56 PM
