fuel rails?
Old Feb 23, 2009 | 12:52 PM
baconsum1's Avatar
Default fuel rails?
anyone install a aftermarket aem fuel rail if so what did u notice if anything and is it worth getting one?
Old Feb 23, 2009 | 12:53 PM
finch13's Avatar
Not worth it unless you have an N/A beast or FI engine. They look pretty though.
Old Feb 23, 2009 | 12:57 PM
baconsum1's Avatar
whats an N/A beast and F1 engine? yea they are tight are they visable at all when installed?
Old Feb 23, 2009 | 01:01 PM
N/A=naturally aspirated
FI=forced induction
pretty much unless you have a motor that requires alot more fuel its worth less
and no you can't really see it when its installed.
not worth it in my opinion.
Old Mar 4, 2009 | 08:56 AM
casinoroyale
Default fuel rails
My shop teacher tells me that your stock fuel rails are more than enogh suppling 50psi to the injector which only need 35psi, thus leading you to your question. The fuel rails are not going to help, what you need are some performance injectors for your engine. Get ready to stop at the gas station more often.
Old Mar 4, 2009 | 09:04 AM
Unless you've done some other stuff, bigger injectors aren't gonna help either.
Same displacement, same cams, same pistons, same same same...
If you inject more fuel, all that happens is you run rich & that doesn't help anything.
Old Mar 9, 2009 | 12:40 PM
falkore24's Avatar
^^^ then the ECU trim cuts down the duty cycle time and you are left with the same power, burning dirtier and less efficient.
I will be doubling my engine's output, but the stock fuel rail is fine for my application.
BigOBob
Jan 1, 2012 02:47 PM
woody
Sep 15, 2010 09:20 AM
fortyfootelf
Jan 22, 2010 07:15 PM
kissbally78
Jan 18, 2009 07:14 PM
colin
Feb 29, 2008 04:20 PM
