Hey guys... How much HP will my f22 have once i swap to an h22 head and turbo(set at like 11-13)?
Over 200hp
Yea u talking about over 200 to 225 hp...
but u should keep ur psi at 6-8 psi keep it safe
you dont wanna mess it up u know.
how difficult would it be to drop a h22 head on a f22 bottom and about how much
whatever the head, valve cover, spark plug wires, distributor, water pipe, ECU, timing belt, thermostat housing and head gasket costs.
How much horse power does the h22 head increase without turbo....
Why do u need new valve cover
ecu which one the f22b1 vtec one or the h22 one...
why do u need a new water pipe and thermostat...
Quote:
ORIGINAL: DA KID RYU
1) How much horse power does the h22 head increase without turbo....
2) Why do u need new valve cover
3) ecu which one the f22b1 vtec one or the h22 one...
4)why do u need a new water pipe and thermostat...
1) not enough to make it cost-effective. like 15. if that.ORIGINAL: DA KID RYU
2) why do you think? (what does the valve cover bolt to...)
3) whichever head your using. Btw this is not easy, and since your even asking that question I would guess you wouldnt be able to do it at this juncture in time.
4) why do you think? different head...
Quote:
ORIGINAL: nafango2
15hp is better den bone stock....lolORIGINAL: nafango2
not thinking of doing it myself or right now if that but i like to learn all this all....
curious to learn bout this topic....
So different head more friction aight
this is what is getting me confused sorry
your not using the same valve cover..
i got a f22b2 im not using the same one or what...
^ Kid - start reading and getting to know things before asking such general questions.
Go over to www.honda-tech.com- sign up, read, read, read. That's the best advice I can give you. If you don't understand it, re-read it again.
