h22 swap into 96' accord
Old Apr 7, 2007 | 02:38 AM
Go Honda GO
Default h22 swap into 96' accord
how do i find out which h22 i need, and i looked at a website and it was sayin something about the vin number, im tryin to get this show on the road
Old Apr 7, 2007 | 02:58 AM
03Sleeper's Avatar
Default RE: h22 swap into 96' accord
The VIN number should be in the lower corner of the windshield...usually driver's side.
Old Apr 7, 2007 | 02:20 PM
poser_pilot6
I dont know that you should worry about the VIN on the donor car. What car do you have? Are you looking for a Prelude from a junkyard, or going for a JDM motor?
Old Apr 10, 2007 | 12:56 AM
Go Honda GO
i was gonna get one of car-parts for cheap, but my friend said something about an incombatitbility that ends up in blown valves
Old Apr 10, 2007 | 01:47 AM
Shadow1992's Avatar
you need an h22a1. The vin number is needed for inspection purposes to legalize your engine for the road. as far as that incompatibilty issue..the only one you may have is going from sohc to dohc..which would require the donor car's ecu, or a reflashed/programmable aftermarket ecu. even then you shouldn't end up with blown valves unless the engine was in poor condition and you over drove it.
Old Jan 31, 2012 | 04:42 AM
silence007's Avatar
tenth vin is the year, I am pretty sure any way.
mjj97
Mar 14, 2012 12:04 AM
94accordexl
Apr 22, 2009 08:24 PM
juansosa57
Jul 2, 2007 08:59 AM
blksniper2000
Jun 28, 2007 09:35 PM
marbro
May 12, 2006 04:29 AM
