H22A in 2001 Accord
Old Aug 7, 2007 | 11:38 AM
Thataccord's Avatar
Default H22A in 2001 Accord
Yea I found a good site (hmotorsonline.com) that sells a 92-95 H22A long block for $1400 with the P13 ecu and I have 2 questions about it. Would the engine work with my stock tranny and is it worth getting the P13 ecu or should I go aftermarket when getting a new ecu because I want to turbo the engine after I buy it.
Old Aug 7, 2007 | 12:10 PM
BlkCurrantKord's Avatar
Default RE: H22A in 2001 Accord
It'll work w/ your stock tranny, get a diff ecu, the P13 will not work.
Old Aug 7, 2007 | 01:10 PM
finch13's Avatar
Go to PGMFI.org and look around in the Wiki (it's down so hunt for the link to the mirror). I want to a say a P72/P75 would work well.
Old Aug 7, 2007 | 02:36 PM
Thataccord's Avatar
Ok thanks that helps a lot.
Old Aug 7, 2007 | 10:56 PM
Velocifero's Avatar
ORIGINAL: Thataccord
bottom line dude, this swap just isnt worth it for your car. it isnt a drop-in like 5th gens. hope your pockets are deep.
Old Aug 8, 2007 | 02:57 AM
ckebottle's Avatar
Here's a write up...it's pretty informative
http://www.honda-tech.com/zerothread...&id=473019
Old Aug 15, 2007 | 11:00 PM
Thataccord's Avatar
Ok well if this swap isnt "the easiest" then what could I get that would have around 200hp and redline high(around 8000+/-) cuz I really wanna swap my stock engine cuz this seemed like a very good one. Would an F20B from a 97-98 work?
Old Aug 16, 2007 | 02:46 PM
1) Why do you want to "redline high" there's really no point unless you're making power that high in the rpm range or you like to spin rod bearings.
2) Yes the F20B will work/fit.
hitek85
Feb 12, 2008 10:32 AM
aboutblank29
Oct 19, 2007 12:15 PM
maro
Apr 11, 2007 06:53 PM
maro
Apr 11, 2007 06:51 PM
jdm_gadget
Jan 7, 2007 04:52 PM
