is the head gasket the same as the gasket for the valve cover?
Old Jul 6, 2007 | 09:12 PM
thunder_x's Avatar
Default is the head gasket the same as the gasket for the valve cover?
my headgasket was reccently replaced and im planning to get a new valve cover, but i dont want to end up replacing the same gasket twice...
Old Jul 6, 2007 | 10:03 PM
noboundaries6289's Avatar
Default RE: is the head gasket the same as the gasket for the valve cover?
a head gasket is below your entire head. Your valve cover sits on your head. It's the part where you pop your hood and the spark plugs go into it. It's a different gasket. And much easier to install than a head gasket. Hope this helps.
Old Jul 7, 2007 | 01:07 AM
thunder_x's Avatar
yea, thanks
Old Jul 9, 2007 | 11:57 AM
Good chance that a new valve cover gasket was put in along with the head gasket. Check your receipts for the headgasket job.
But no, they're not the same thing. Look at where your exhaust manifold bolts to the head. Valve cover gasket is above the manifold, head gasket is below.
03Sleeper
Jun 11, 2008 08:54 PM
crvone
Dec 29, 2007 02:13 AM
Fez
Apr 9, 2007 11:32 AM
richomundo
Mar 13, 2007 09:25 PM
PIGGEBANK
Aug 13, 2006 12:13 AM
