oil in tubes not valve cover gasket
Old Mar 13, 2007 | 07:59 PM
richomundo's Avatar
Default oil in tubes not valve cover gasket
I had noticed that there was oil in my spark plug tubes. I had my valve cover gasket replaced as well as alllllll the other seals and belts replaced at Brake Masters.
A week later I notice my car is idling funny again so I pull out my spark plug tubes and there was oil still in 3 of the 4 tubes.
I took it back to Brake Masters and they were happy to replace the valve cover gasket and everything else a second time, no charge.
I went back later that day and he told me that it was still leaking.
I asked him about it and he said he saw it before on his civic, but it wasn't as bad and he never fixed it because it didn't cause that much of a problem.
Have any of you ever seen this? I'll take some pictures and post them a little later. Thanks for all your help.
Old Mar 13, 2007 | 09:25 PM
deserthonda's Avatar
Default RE: oil in tubes not valve cover gasket
it sounds like the lower rocker arm seals .. go to our DIY section there is a write up step by step on how to repalce the seal upper and lowers,,
( oil in spark plug tubes )
B501
May 27, 2012 08:28 PM
thunder_x
Jul 9, 2007 11:57 AM
MALSR
Jan 5, 2007 04:59 PM
patcal
Nov 27, 2006 11:33 AM
deserthonda
Apr 16, 2006 04:22 AM
