Help save my cb7
Old Jul 11, 2023 | 02:50 AM
91AccordSE's Avatar
Default Help save my cb7
I've got a 91 Honda Accord SE I have a problem with the idle I've checked all the hoses that I can find replace the throttle body and all the sensors and it's still idles High. So high that when I put it in gear the tires chirp and when I let off the break it takes off and will stay running at 45 mph without even giving it gas it's got to be something I'm missing. I also notice that the transmission is starting to slip and it won't go into passing gear I don't know if that may have to do with the same problem possibly a vacuum leak? Anybody have any answers or tips?
Old Sep 10, 2023 | 04:56 PM
Fischypants's Avatar
It sounds like your throttle position sensor isn't set correctly. I'm not a mechanic but that's probably where i would start. If you werent exaggerating about 45mpĥ at idle then i would also check the linkage concerning your gas pedal. Just my 2cent im super curious what you find, so keep the forum posted.
iusedtoownasubaru
May 29, 2023 09:57 AM
Gary L
Oct 6, 2008 04:27 PM
peewee
May 28, 2007 05:51 PM
zzzz
Jun 30, 2006 08:51 PM
wth71
Jun 29, 2005 03:02 PM
