If it wasn't for bad luck!
Old Oct 6, 2008 | 08:02 AM
Gary L's Avatar
Default If it wasn't for bad luck!
I wouldn't have any at all!
Working on my new, old '91 Accord wagon and tracking down a low idle problem. Following the proceedures to clean the EGR and the idle control valves and then decided to clean the throttle body.
Bought a couple cans of T Body cleaner and after removing the intakeplastic/rubber tube I began spraying into the T body.
On the first shot the little straw on the can blew off and went right into the throttle body and was gone.
I ended up having to take the entire top right off to get the straw out of the manifold but in the end I was glad because I did get to do a real nice job cleaning all the throttle plates.
Car idles much better now but still on the low side while in gear and I suspect this is the nature of the car. I could adjust the idle up but then when not in gear it would be too high. I think it best to leave well enough alone for now.
I did find that a quick drop of loctite crazy glue to glue the straw on to the can is a very good idea if you are working where the straw could possibly blow off and become a chore!
Gary
Old Oct 6, 2008 | 08:07 AM
08coupex's Avatar
Default RE: If it wasn't for bad luck!
Atleast you were able to get the straw out. Most of the time I take the straw off because I dont want that to happen and for the most part after the first use I lose it anyway.
Old Oct 6, 2008 | 08:16 AM
Vipers4Life's Avatar
LOL! The straw shot right into it rofl! I should consider cleaning mine too. Ill make sure to glue the straw onto my can so i don't do that eathier lol. Glad you got it out!
Old Oct 6, 2008 | 08:48 AM
falkore24's Avatar
If you disconnect the intake pipe, what do you need the straw for?
Old Oct 6, 2008 | 11:52 AM
klrspz's Avatar
Hmm.. i usually use carb cleaner... am I thinking of something different? The butterfly valve on the intake?
Old Oct 6, 2008 | 11:54 AM
ORIGINAL: klrspz
that would be the throttle body
Old Oct 6, 2008 | 12:30 PM
finch13's Avatar
ORIGINAL: klrspz
It's all pretty much the same between intake/carb/brake cleaner...
Old Oct 6, 2008 | 04:27 PM
falkore24's Avatar
I've heard there is a difference btw carb and TB cleaner, but so far nobody has been able to tell me what the difference is .... and I'm too lazy to look it up ..... I don't have a carb, so I use the other stuff!
96FiveSpeed
Jun 12, 2013 12:05 AM
LordAccord
Jan 8, 2013 05:08 AM
giulio76
Dec 29, 2012 11:16 AM
Hondafan454
May 23, 2010 07:40 PM
19Accord97
Sep 7, 2006 11:53 PM
