high flow cat = burning oil ??
Old Aug 20, 2008 | 09:49 PM
MrGmo's Avatar
Default high flow cat = burning oil ??
so im not sure about this one... i asked my friend (previous owner of a 6th gen) why i was burning so much damn oil... he said it was probably the catalyc converter...
its a high flow cat... in my opinion its probably the same as a test pipe... coz it is straight through... no restriction...
in any case .... my car burns alot of oil.... so my question is...
1. how can i get it to stop, without rebuilding the motor (id rather just do a h22 swap)
and
2. could it be the cat thats the culprit of my situation???
Old Aug 20, 2008 | 10:19 PM
Default RE: high flow cat = burning oil ??
i dont see any possible way of a cat causing you to burn oil, its usually piston rings that cause this, but there are also other reasons, and there is really no way of telling without doing tests
Old Aug 20, 2008 | 10:47 PM
MrGmo's Avatar
im interested... what test's are these? ....like leak down? or compression?......
i pulled my plugs to replace them and they didnt look drenched in oil... but had a white coat on them on the tips
Old Aug 20, 2008 | 10:52 PM
both tests will help, oil in the spark plugs wouldnt really indicate burning oil, rather than leaking valve cover gaskets
Old Sep 24, 2008 | 05:02 PM
Jmoney's Avatar
Worn valve guides, or bad valve seals possibly
Old Sep 25, 2008 | 05:06 PM
Hobbin's Avatar
Is oil or other fluid actually leaking from your engine? If so try to find hte spot where.
Check your compression too
pyaarawala
Jun 1, 2007 01:19 PM
ohiostatepimp22
May 1, 2007 09:35 PM
TedsF23accord
Apr 8, 2007 10:22 PM
BLuEPiTBuLLz
Jan 23, 2007 01:02 AM
bpo145
Aug 5, 2006 01:11 PM
