High STFT on a 2005 Honda Accord
Old Nov 20, 2022 | 08:08 PM
Carrameow's Avatar
Default High STFT on a 2005 Honda Accord
I have a 4 cylinder 2005 Accord with a high STFT of 45%. The problem reports as a P0171. Despite the high STFT, the car starts and performs normally.
I hope someone can give me some advice.
I have done the following without making the STFT go away:
1 I have replaced the fuel pump and fuel filter and had the injectors professionally cleaned. Fuel pressure is 50 psi.
2 I've replaced both O2 sensors.
3 I have swapped the MAF sensor with a known good one.
4 I found one vacuum leak in the Front Engine mount and replaced it.
5 I've blocked off/ plugged all the vacuum lines, ie the brake booster line, the purge line, the PCV hose line.
6 The MAP sensor reads 4.5 psi at idle and 3.6 psi at 3000 rpm. Is that correct?
7 I don't think there any intake manifold gasket leaks. I've used starting fluid in the area. There are no fuel injector seal vacuum leaks, which happened to me on another car.
Can someone give me guidance on what to check next?
cukaracha
Jul 17, 2014 04:05 PM
Rcruz
Mar 2, 2014 07:19 AM
TexasHonda
Nov 2, 2013 07:42 AM
Bertdog
Dec 24, 2012 08:31 AM
500$accord
Oct 25, 2010 09:21 AM
