P0171 and poor fuel economy
Old Oct 25, 2010 | 08:08 AM
500$accord's Avatar
Default P0171 and poor fuel economy
Having an ongoing issue with some mild performance issues and now recently fuel economy that has dropped from between 26-28 mpg to around 22. This has been consistently lower for a month or so. The code P0171 shows up intermittently.
I have verified fuel pressure at 30+psi at idle with 40+ psi with regulator vac disconnected.
My Egr valve is new and receiving vacuum, although it seems kind of low, I guess... 4 inHg at max. P0171 would indicate EGR valve open, where a low pressure would do the reverse, so not really worried about that.
My valves were adjusted about 20K miles ago.
I tried to check for vacuum leaks and found none.
I am down to looking into the primary O2 sensor and and exhaust manifold leaks.
If anyone has other suggestions, I could use a few good ideas.
Also, it seems kind of counterintuitive that I could have a lean condition while I am having poor fuel economy.
Thanks !!!
Old Oct 25, 2010 | 09:21 AM
It most likely is the primary oxygen sensor. I recommend a Denso O2 sensor.
WastingLight
Jun 12, 2015 11:07 AM
gdimattia
Nov 30, 2014 09:02 PM
Newby
Mar 4, 2011 10:56 AM
TBJ
Jan 24, 2011 12:55 PM
iqoair
Aug 27, 2006 10:39 PM
