honda accord 1992 repair finnaly decided
Old May 17, 2006 | 01:17 AM
accord1992
Default honda accord 1992 repair finnaly decided
Mhmm Very new at at this..finnaly decieded to refix mah honda.. What are the maintanece that is required that i should b aware about?
My transmission is an automatic n it revs up when the car in drive..den i have to let mah foot go frm the gas..it was said that it would slips on second gear..it sounds like a manual..n i need a new axle on right if im correct..when i make a wide turn i can hear clickin frm the front..
Old May 17, 2006 | 02:45 AM
Default RE: honda accord 1992 repair finnaly decided
Hello New member Welcome to the forums..The New Member forum would be a good place for you to go and introduce yourself when you get the time.
Thanks for joining...
Old May 17, 2006 | 02:47 AM
How long have you had this 1992 Honda? And what have you ever done to it..reason I ask is because you have a few good problems to take care of in there.
Old May 17, 2006 | 03:05 AM
deserthonda's Avatar
First off.......welcome
first thing you should do is to chk the tranny fluid, ,,
if low ,, chk for leaks, repair leak, replace fluid and test drive
if planty of fluid, replace tranny fluid using only Honda ATF-Z1 .. drain and add 3 qts , test drive car,,
if it still slips you might have worn clutches, torn clutch pack o-rings, or other internal issues
as for the clicking noise ,, i would not do anything till you figure out the tranny issue first ..
okie-f22
Jul 17, 2009 12:34 AM
Tippman7641
Apr 27, 2009 11:22 PM
Tippman7641
Jul 8, 2008 08:48 AM
otto
Jan 19, 2008 09:12 AM
