honda accord f22 mini me swap
Old Dec 12, 2013 | 01:51 PM
jschmidtf22's Avatar
Default honda accord f22 mini me swap
Hi I own a 95 accord non vtec and am buying a vtec head from the junkyard and rebuilding it for performance and eventually planning on swapping heads for the vtec as well. Ive never really done a job like this and am looking for some of your assistance of what im going to need to do/buy for the mini me swap. As far as ECU and oil lines. Anything thats involved I appreciate everyones input.
Old Dec 12, 2013 | 01:53 PM
Any information on anything ill need helps thanks guys/girls
Old Dec 12, 2013 | 05:41 PM
Not that bad. There is an "orfice" in the deck of the block you will need to remove. New/different timing belt as they are different....I think the cam gear is larger = more teeth.
ECU, check. Run a few wires from the ECU to the vtec solenoid/pressure switch.
Pretty much all I can think of right now.
Old Dec 12, 2013 | 07:51 PM
I plan on putting aftermarket cam and gear in. How would I know what belt is right and is there anything else involved in timing? Timing is something im clueless on. Gonna get help w that. And if you can explain more about this orfice to me?
Old Dec 12, 2013 | 07:52 PM
Am I going to need the ecu out of the other honda with vtec or can I keep my ecu
Old Dec 12, 2013 | 07:58 PM
CD5Accord's Avatar
As stated you need the timing belt from a 94-97 F22B1 VTEC
The oil control orifice is a brass plug located in the center of the engine block surface. You need to remove it in order for enough oil pressure to enter the cylinder head from the block. Without removing the orifice you will not have the proper oil pressure for the VTEC assembly and it will not engage.
You will need a VTEC ECU out of a VTEC Accord... that being said you should find out if the camshaft that you want to install will require ECU tuning. If that is the case you will need a tunable ECU, and your stock ECU is not tunable.
Attached Thumbnails honda accord f22 mini me swap-oil-control-oriface.jpg   honda accord f22 mini me swap-engine-block-surface.jpg
Old Dec 12, 2013 | 08:40 PM
Even with an aftermarket gear I can use a stock vtec timing belt?
Old Dec 13, 2013 | 12:36 PM
CD5Accord's Avatar
Yes, the aftermarket gears are made with the same dimensions as the OEM gear. Unless you buy one that was made for a different engine. If you buy a TB drive gear for the F22B1 you will use the OEM timing belt.
Aftermarket timing belt drive gears are not like the aftermarket alternator and power steering pulleys that you can buy. They don't come in under drive sized.
Old Dec 13, 2013 | 05:30 PM
Need to know the "plan" of the build. If you are going for an adjustable cam gear, it sounds like you have some slightly bigger plans?
Your 95 is OBD-I which is a good thing because if you are going for bigger plans you will need to get it tuned as stated - and the options for OBD-I vs. OBD-II are much, much greater. If this is where you are going, you might want to talk to the tuner before getting too far so they can give you ideas - sometimes they only like working with certain products.
minchina
Sep 8, 2012 08:18 PM
AbaZ
18
Jul 16, 2008 10:23 PM
SpanishN00b
Jul 29, 2007 07:11 PM
95bentleyLX
Apr 22, 2007 04:29 PM
225 Tuning
Oct 25, 2005 10:54 AM
