how can i increse low end torque
Old Jan 14, 2008 | 12:14 AM
Jtweaz's Avatar
Default how can i increse low end torque
any suggestions?
Old Jan 14, 2008 | 09:25 AM
00AccordLX5spd's Avatar
Registered User
Default RE: how can i increse low end torque
use the search function on this site
Old Jan 22, 2008 | 03:25 AM
YeuEmMaiMai's Avatar
there really isn't tooo much you can do to solve the J30a lack of torque problem. it is a byproduct of the following
1. small intake valves
2. only 1 intake valve opens when vtec is not engaged
edit there are things you can do but that involves doing things like changing out crank, pistons and heads.....and that ain't cheap
Old Jan 22, 2008 | 09:22 AM
falkore24's Avatar
Just a minor correction. Both intake valves open in low-VTEC mode, but one opens just slightly to prevent pooling of fuel and to enhance the swirl effect in the cylinder. As far as the power goes, it might as well be closed.
Old Jan 22, 2008 | 06:26 PM
I'm just simplifying the discussion that's all asI am well aware that the second valve opens just enough to prevent fuel pooling at the valve.....but for the purposes of engine performance it is just one valve open.
Old Jan 23, 2008 | 09:48 AM
marbro's Avatar
i still say get a high volume air compressor and direct port it and let it go full blast ^_^
steviebix
Nov 21, 2007 10:52 AM
liam71234
Nov 5, 2007 02:57 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
6genex
Oct 9, 2007 04:15 PM
len1967
Oct 3, 2006 03:03 PM
