how much is it to resleeve an h22?
Old Oct 31, 2007 | 10:47 AM
liam71234's Avatar
Default how much is it to resleeve an h22?
i found a h22 for my accord for $300 the engine needs resleeved how much is that gonna run me? i heard its really expensive and will run me around $1000 but if i was gonna do that i'd want to get the whole engine rebuilt and bore the cylinders out. what is a good size to bore a h22 engine to? what are good pistons and rods for a h22? and i'd want to get the head ported and polished whats a good cam for the h22? what size injectors would i need after boring the the engine? where could i get a rechipped ecu/ whats a good brand? how much do you think it willl cost to do all of this to the engine?
Old Oct 31, 2007 | 12:21 PM
BlkCurrantKord's Avatar
Default RE: how much is it to resleeve an h22?
One too many questions at once....if you're really serious about it its gonna end up costing you a couple grand to rebuild that engine. Sleeves alone are normally $5-600, its the process of removing the old and installing the new that gets expensive.
Old Oct 31, 2007 | 03:28 PM
marbro's Avatar
where i live theres a shop that can do the resleeving for 1600 and thats in omaha
Old Oct 31, 2007 | 08:41 PM
Shadow1992's Avatar
87mm is a good overbore, maximum is 89mm. Arias makes good pistons, BC makes a good stroker kit, Carillo and Crower make good rods. Crane makes good cams. And you wouldn't need to replace the stock injectors for simply overboring. All this would easily cost you $2000-$3000. If you want to swap out the ECU, go for a stand-alone like one from AEM. This way you can tune your engine incredibly well, and if you do future upgrades its as easy as plugging the unit into a computer to change the program. Downside is the stand alone's can cost $1500 themselves.
RobinsonRicer
Dec 22, 2013 08:42 AM
Sadus
Sep 6, 2011 11:29 PM
NICK63
Nov 2, 2009 11:57 AM
BMW97
Feb 10, 2006 03:48 PM
