I need help swapping F23A1 into 94 accord ex
Old Jun 25, 2008 | 09:52 PM
VTEC!MASTER
Default I need help swapping F23A1 into 94 accord ex
Hello all,
I have a 1994 Honda Accord EX sedan with a F22B1 vtec 5-speed with 123k. The current engine is burning alot of oil and has killed my gas mileage. I have located a 2.3L F23A1 vtec from a 1998 Accord LX with 78k on it at a local junkyard for 300$. I would like to do the swap but am unsure about any problems/complications. Is this a bolt on swap?? or is there any modification needed?? I searched the forum but couldn't find any past talk of this particular application. I really don't have any idea about the compatability of this swap, so any input/experienc/advice is greatly appreciated. Thank You!!
Old Aug 22, 2008 | 12:17 AM
Hobbin's Avatar
Default RE: I need help swapping F23A1 into 94 accord ex
Is it worth all the money and time?
I'd just fix up the engine you have. Put in new seals, clean it out, replace what's necessary.
Old Aug 22, 2008 | 11:27 PM
blinkz0rz's Avatar
I can't be 100% honest, but if the bellhousing matches up to the transmission you should be fine. Just make sure it uses the same motor mounts too.
The biggest problem will be the wiring.
Old Aug 28, 2008 | 11:24 AM
VTEC!MASTER
Hey, thanks for the input.I have since scrapped the swap idea, and decided to pull the head and replace valve guide seals and all other seals/gaskets that come in a head gasket set. My engine has perfect/even compression across all 4 cylinders. So i think the problem is in the top end...
RYsoJDM
Jun 13, 2013 08:16 PM
EazyMartin
Feb 23, 2013 07:40 PM
F22DNH
Jul 12, 2011 10:20 PM
pwrhouss
Sep 12, 2008 02:13 PM
dewman2004
May 14, 2007 10:57 AM
