Swapping v-tec into 95 Accord
Old Sep 11, 2008 | 06:40 AM
pwrhouss's Avatar
Default Swapping v-tec into 95 Accord
I know this has been asked several times but I had a hard time searching for the topic. When swapping my 2.2 for a v-tec 2.2, what needs to be changed. My car is a 95 Honda Accord wagon. Thanks
Old Sep 11, 2008 | 07:47 AM
Default RE: Swapping v-tec into 95 Accord
depends what motor you are putting in, there is more than one 2.2 vtec
Old Sep 11, 2008 | 08:04 AM
I would think a minimum is ECU from same Vtec vehicle. Vtec is enabled by ECU. Hopefully your wiring harnesses are compatible. If not, then some major wiring would be required. This would be a real PIA.
Old Sep 11, 2008 | 11:00 AM
finch13's Avatar
You can actually get a little IC circuit and solder it into the ECU with a few resistors and enable VTEC without dropping a ton of cash on a new ECU. You're probably going to need the wiring harness as well.
Old Sep 11, 2008 | 04:28 PM
pwrhouss's Avatar
I would be using a 2.2 v-tec from a 95 Accord. For some reason I was thinking it would just be a simple swap but maybe not. Surely somebody here has done a swap like this that knows the ins and outs.
Old Sep 11, 2008 | 04:31 PM
you would be wasting your time. spending the money to buy a new motor, add vtec, and possibly labor to pay for the swap if you dont do it yourself........to gain 15hp. It would be hardly noticeable.
Consider a H22 swap which a is 2.2 out of the prelude. which would be a 70+hp increase
Old Sep 11, 2008 | 09:38 PM
pwrhouss's Avatar
If I went with the H22 out of a Prelude, what years should I look for? Also, what other parts would I need for the swap. This is not going to be a just for the hell of it swap, but rather when my current 2.2 goes. It currently has about 250K miles and I am just planning ahead. Thanks for the info.
Old Sep 12, 2008 | 12:47 AM
92+ as long as its not out of a sh
Old Sep 12, 2008 | 02:13 PM
00AccordLX5spd's Avatar
Registered User
If you want an economical engine swap, I wouldlook around atsalvage yards (try to find one that lets you do all the disassemply on your own - we have one im my town called Pull-a-Part)and rip out the engine, wiring harness, and ecu from a donor car. Usually the salvage yards that let you do all the parts removal yourself will be dirt cheap.
martinez289
Mar 1, 2013 06:33 AM
EazyMartin
Feb 23, 2013 07:40 PM
Bilster
Sep 7, 2011 03:36 PM
F22DNH
Jul 12, 2011 10:20 PM
VTEC!MASTER
Aug 28, 2008 11:24 AM
