Idle issues
Old Apr 23, 2007 | 10:05 PM
mig25's Avatar
Default Idle issues
When I crank my Accord ( Cold engine )the RPMs go to about 1000 RPMs , then when the engine warms up it revs up and down , up and down, by itself .
Any hints or tips ?
Thanks
1993 Accord 10th Anyversary edition auto 2.2 L engine.
weldas@msn.com
Old Apr 23, 2007 | 10:37 PM
sssexy70's Avatar
Default RE: Idle issues
Sounds like a typical vacuum leak. Take a gas torch and run it underneath the car WITHOUT LIGHTING IT and if the engine begins to rev higher you have a leak in that hose.Otherwise, there are a lot of things it could be, read prior idle related posts which may give you some other ideas.
Old Apr 24, 2007 | 02:27 AM
deserthonda's Avatar
why don't you just go to the DIY section and read up on the post ,,,,,, surging idle
Old Apr 24, 2007 | 09:24 AM
mig25's Avatar
[:@]Yup, Sorry I did read about it now that I located the search button ...
For us newbies the search button sometimes is hard to see, remember we are not used to the page.
Is there a way to make the Search button more visible and more user friendly ?
Thanks for all the info guys
Old Apr 30, 2007 | 09:51 AM
mig25's Avatar
I have pingpointed the Problem and fixed it.
My fast idle valve was totally corroded .
The botton nipple on the valve, where the hose carrying the antifreeze connects to , broke off and clogged the hose completellly.
I have replaced the Fast Idle valve and the hose.Problem solved.
Thank you For the instructions doing a search on Idle.
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
drummer1279
Oct 4, 2006 12:20 PM
