Idle Problem Need Help
Old Apr 14, 2007 | 05:32 PM
m3st1zo
Default Idle Problem Need Help
I Own A 92 accord EX, I fixed the idle problem when starting up the car but when I drive it does not want to pass 2 RPM. It begins to shake, Can anyone give some advice on what to do?
Old Apr 14, 2007 | 07:22 PM
deserthonda's Avatar
Default RE: Idle Problem Need Help
ORIGINAL: m3st1zo
what was the issue with the idle before you fixed it ?? what did you do to fix it ?? .. if car did not have the same issue before you did the work,, i would make sure that everything is properly reconnected
chk engine lite on ??
samantharose826
Feb 3, 2013 06:39 PM
RWilliams
Jul 24, 2011 09:16 PM
mamtsberg
Mar 17, 2010 09:15 PM
92Inspire
Aug 13, 2006 03:37 PM
fperezal
Jun 14, 2006 05:03 AM
