ignition help again
Old Sep 24, 2007 | 02:38 AM
hawaiian5's Avatar
Default ignition help again
ok, ill try this again. i wanna upgrade my ignition, and dont tell me i dont need to. i just want to!. im not looking for extra hp or going all out racing, i just want something one level better than my oem. now can someone help without saying i dont need to upgrade?. i was told that a better coil, better distributor cap and a better rotar, along with 8.5 plug wires with irridium plugs will be enough. if this is so, CAN SOMEONE PLEASE TELL ME WHERE I CAN BUY THEM ONLINE BECAUSE I CANT FIND ANY SITE THAT DOES!!!. i been looking all night, and cant find a site that has those parts for my car. PLEASE HELP PEOPLE. thx and aloha.
P.S.
i have a 2003 accord ex v6 sedan.
Old Sep 24, 2007 | 08:40 AM
00AccordLX5spd's Avatar
Registered User
Default RE: ignition help again
I cannot recommend anything because there is nothing out there that will not inevitably mess up something on your ignition. If you buy an aftermarket ignition system, you better keep a fire extinguisher in your car.
Old Sep 24, 2007 | 09:28 AM
falkore24's Avatar
You can't find them because your car doesn't have a distrubitor, much less a distributor cap. The rotor goes inside a distrubitor, so you don't have that either. Wires go from a distributor to the plugs, but you don't have a distrubitor so they're out too. That leaves the coil ...... you can't get an aftermarket coil since your engine has coil-on-plug, or 6 small coils that fit right on top of the spark plugs -- I've looked to upgrade these, but can't.
Spark plugs you can do. NGK Iridium IX plugs are very highly rated. Next would be Denso's. If you plan to rip out the ignition system and build a complete stand alone capacitative discharge system, the iridium plugs are no good. The additional power of this type of system will fry off the small iridium tips. Also if you plan to spray nitrous, no platinum plugs. The best for an OEM ignition is the NGK Iridium IX. The best for an aftermarket ignition system would probably be a full platinum plug (I'm not impressed with multiple grounds since I've run plug tests and the multiple ground plugs didn't do any better than single ground equivalents but a lot of people like them). The best for an aftermarket system with nitrous spray are the ZEX plugs, IMO.
Please put your car info in your signature.
Old Sep 24, 2007 | 09:37 AM
Registered User
I didn't even realize he had a 2003 V6. I was just assuming it was one of the old "so I want to add MSD to my car" threads. Good post Falkore.
shehadehd
Sep 20, 2012 05:20 PM
bigb609
Dec 27, 2011 07:18 PM
Resatimm
Jan 5, 2007 02:03 AM
Jul 24, 2006 03:55 AM
Jun 2, 2006 02:24 AM
