Increasing Piston Stroke
Old Jan 12, 2009 | 02:05 PM
  #71
falkore24's Avatar
Default RE: Increasing Piston Stroke
Please research G23.
Old Jan 12, 2009 | 04:31 PM
  #72
Its popularslang to call that a G-series engine, because F-series block & H-series head. That, together with not many people beingaware that an actual G-series engine exists.
Honda actually made aG-series engine - 5-cylinder used in Acura Vigor.
Still, its a good search string for the F& H combination.
Old Jan 12, 2009 | 05:26 PM
  #73
BlkCurrantKord's Avatar
ORIGINAL: AccordLXMaster
ok meaning what??...like...are they saying use just the top portion of the h22 and leave the rest f23??...or like how exactly is this done?...and this is better than the h22 swap???....and as far as him saying "bisimoto runs F heads and makes over 300whp all day."...thats with what mods?? or do you know?
G23 =
H22 or H23 head on a...F23 or F22 block. It bolts together with ARP H23 headstuds.
Bisimoto runs 17:1 compression on a single cam F22engine with race fuel and carburetors. Not something you're likely to copy.
Old Jan 12, 2009 | 05:55 PM
  #74
AccordLXMaster's Avatar
dang thats all you need?...im thinking of doing this myself or in fact just taking it to a shop to have it done...so all it needs it headstuds?...what all would it need done to it for it to work properly
Old Jan 12, 2009 | 05:59 PM
  #75
You would need to convert all the timing belt pieces on the block over to h23 timing belt pieces. I thought I had heard of some oil passages having to plugged, and forgot what head gasket you have to have.
Old Jan 12, 2009 | 08:41 PM
  #76
H22/H23 head
H23 timing components as live2rice said...
Actually ya know what....go to honda-tech, look it up. All the parts you need are listed there. Also, DarksideAccord on 6thgenaccord.com did it as well. Should also point out that you really should have a 5spd first before even thinking about doing this.
Old Jan 12, 2009 | 09:45 PM
  #77
cjdm98's Avatar
yes..while your over on honda-tech,look at there manual f23 manual swap as well.
Old Jan 12, 2009 | 11:07 PM
  #78
why are you saying i should have a 5spd??...other than speed will there be a difference??...and its pretty useless if i get a 5spd and then cant drive it...lol
Old Jan 13, 2009 | 04:54 AM
  #79
JohnL's Avatar
ORIGINAL: BlkCurrantKord
It's not like the sleeves are just going to blow out from 8-10psi of pressure. Other things will go long before the sleeves do.
ORIGINAL: falkore24
Yeah, thats true, but Ive heard about the FRM sleeves getting brittle and cracking from lots of stress cycles caused by the additional pressure of a turbo ...... these cases most likely had over 10 psi though.
Forgive me if I'm pointing out the bleedin obvious, but of course it isn't the psi that the turbo is producing that might cause a problem directly, it's the indirect increase in combustion pressure that is a product of a supercharged mixture, which is many many times greater than the supercharged psi, and more so the higher the supercharged pressure (though there must be a point of diminishing or reversing return at some point).
Of interest, the great majority of the cylinder pressure rise is from heated / expanding nitrogen (which of course is an inert gas not involved in the combustion).
Old Jan 13, 2009 | 04:58 AM
  #80
JohnL's Avatar
I'll spell it out, since the penny hasn't dropped yet; the auto box will break because it's not very strong...
