J30a1 upgrades or swap out
Old Nov 30, 2009 | 03:05 PM
oIACCORDIo's Avatar
Default J30a1 upgrades or swap out
i have a 98 honda accord coupe with a j30a1 and ive been trying to do research on a way to upgrade my engine. Ive heard about swapping out parts from a TL or CL and want to know what parts i can swap out. Also im wondering if i can swap out this j30a1 with any other j-series engine that will fit in my accord. any info will help, thanks.
Old Nov 30, 2009 | 03:59 PM
Lightbulb Hope This Starts You On Track
Engine used in the extinct Acura 3.0CL line, as well as the now-obsolete sixth-generation V6 Accords. Rated 200HP, 195lbs/ft. of torque. Utilizes multiport programmed fuel injection (PFI) and SOHC VTEC. Spark plugs are driven by ignition coils rather than a distributor in later models. Mileage: About 21 street, 26-28 on the highway. Can be mated to either an automatic or manual transmission and is usually (always?) installed in transverse mount fashion, since the cars it is found in are all FWD.
This engine is fairly large compared to other 3.0-liter V6es and takes up a lot of the compartment in the Accord and Acura CL engine bays. This makes it a little harder to work around, and especially mod. Nevertheless, there are plenty of mods available from GReddy, Aerospeed, and others.
One particularly interesting mod that will work with the J30A1 can be found here:
www apexi dot com good info
This mod does two things. One, it optimizes fuel flow. Two, it controls VTEC engagement points. It does these two things in concert, which results in a boost in performance. It also tells you whether VTEC is on or off, as well as the percentage of throttle and engine revs. At the time of writing (7/20/2001), CompTechUSA wwwcomptechusacom) is about two months from releasing a supercharger for this engine. At a mere 6PSI, they claim it takes a stock Accord from 180HP to 230HP. (That's at the wheels, not the engine's BHP. Flywheel HP is generally 12-13% more than what you get at the wheels.)
(I like it!)
Old Nov 30, 2009 | 04:17 PM
finch13's Avatar
You can swap in any Honda/Acura V6 6spd manual and you can swap in any Honda/Acura V6... with the right parts...
MikeyMike on 6thgenaccord.com has a 3.5L 6spd in his Accord coupe. It's expensive though, the right engine harness, Richies, is $700 alone.
Old Dec 1, 2009 | 01:11 AM
oIACCORDIo's Avatar
thanks for the info guys, lots of help. would i have to do any mods to front axel with transmission swaps? would any 6spd transmission fit?
Old Dec 1, 2009 | 01:57 AM
oIACCORDIo's Avatar
would you happen to know what car mike got his 3.5L from?
Old Mar 20, 2012 | 10:48 PM
pjschmitt's Avatar
How does taking a 97 acura cl 3.0 auto premium and turning it into a 6 speed standard sound? Anyone done it here?
cjdm98
Jan 16, 2009 11:54 AM
atarikid07
Apr 13, 2008 11:25 AM
mikel6690
Jun 6, 2007 04:20 PM
stefanb21487
Jun 4, 2007 12:39 PM
