JDM Engine for Turbo F-series
Old Sep 11, 2008 | 05:40 AM
PTVDesign's Avatar
Default JDM Engine for Turbo F-series
What better (and cheaper for building turbo) engine for turbo 10 PSI?
1) F22B (prelude si 96year DOHC comp.ratio 9 160hp)
2) F22B (accord wagon SOHC comp.ratio 8 145hp)
thx
Old Sep 11, 2008 | 06:14 AM
PTVDesign's Avatar
Default RE: JDM Engine for Turbo F-series
i will use JDM engine
Old Sep 11, 2008 | 07:55 AM
generally the lower the compression ratio the better for turbo
Old Sep 11, 2008 | 08:06 AM
PTVDesign's Avatar
DOHC or SOHC - is not important?
Old Sep 11, 2008 | 08:07 AM
not as important as compression ratio, the lower the compression ratio the more boost you can run safely
Old Sep 11, 2008 | 08:10 AM
PTVDesign's Avatar
ok thanks.
for turbo, maybe not need swap my F18B (sohc without vtec 125 HP 16.8 kg*m / 4500 comp ratio 9:1) on F22B (sohc 135-145 hp)?
Old Sep 11, 2008 | 08:12 AM
i'm not all too familiar with the F18 as it was never offered in the US and isnt a popular swap(dont know anyone who has done that swap in the states) but i would say you could prob save some money and just boost that and not do a swap.
Old Sep 11, 2008 | 08:28 AM
PTVDesign's Avatar
on f18b sohc without vtec EXHOUST is 4:1 on F22B 4:2:1
on odometr 262000 km maybe need swap? )))
engine work perfectly
Old Sep 11, 2008 | 08:29 AM
the exhaust manifold really doesnt matter if your turboing it as you would need a turbo manifold. and perhaps just rebuild it, would still be cheaper than a motor swap
Old Sep 11, 2008 | 09:29 AM
PTVDesign's Avatar
thanks
g22cd5
Jul 30, 2009 07:15 PM
PTVDesign
Oct 28, 2008 09:20 PM
PTVDesign
Jun 24, 2008 01:25 PM
BuntinBoy9
Nov 11, 2007 06:56 PM
o4vroom
May 20, 2006 02:47 AM
