99 honda accord ex 2dr dying problem
Old Sep 11, 2008 | 08:23 AM
kimberlei
Default 99 honda accord ex 2dr dying problem
I have a 99 honda accord ex. about 3months ago it started dying. you can be driving down the road and it will just die but.... it starts right back up you dont have to pull over it just dies and restarts that quick. i was told it was possibly the memory? i love the car but hubby says it has to go unless we can figure out the problem.
Old Sep 11, 2008 | 08:49 AM
falkore24's Avatar
Default RE: 99 honda accord ex 2dr dying problem
Do you have a lot of cr@p hanging from your keychain? Could be a broken electrical half of the ignition switch. Diagnostics are necessary first, but if this is the case, it can be DIY fixed for under $70.
Old Sep 11, 2008 | 04:53 PM
kimberlei
ok i think that may be it now i need to know where the water pump is located and how to install i cannot find any free online manuals can you help
Old Sep 11, 2008 | 05:02 PM
falkore24's Avatar
hmmm .... I can't help with the manuals, but there may be directions in the DIY section ... not sure about that one. If you look at the accessory belts, the water pump is the small chubby pulley. I had a V6, so it may be a bit different, but if I remember correctly, it was about 2" diameter by about an inch thick.
So was the problem the keychain? Where did the water pump thing come from?
notoriousganstr
Mar 23, 2013 08:26 PM
Junkers101
Feb 19, 2011 12:24 PM
njmodi
Jun 29, 2009 12:11 PM
AKcord
May 23, 2007 09:34 AM
adamc44
Mar 26, 2007 11:05 PM
