junk yard engine
Old Jan 28, 2012 | 09:09 AM
beastro's Avatar
Exclamation junk yard engine
I was woundering what I should check on it befor I actually but it to make sure its good. I will check the condition of the oil and spark plugs. but what els should i check on it? the engine has 80k on it so I will be replacing the timeing chain. any advice would be great thanks
Old Jan 28, 2012 | 09:24 AM
Pull spark plugs and turn engine over to make sure water is not in cylinders and pistons move easily in cylinders.
You could attach a battery and turn engine over w/ starter to test compression. Some oil squirted in cylinders would provide a better indication of compression. Compression test will also indicaate any leaking valves.
When I bought a used engine (Dodge V8), I went by the shops to see how they stored the engine. Some leave outside in vehicle (bad) and some remove and store inside (best). First engine I bought was dropped at mechanics' shop outside in a driving rain storm allowing water into engine. The salvage yard replaced w/ a similar engine that worked well.
Old Jan 28, 2012 | 09:54 AM
beastro's Avatar
Good idea. this engine is in the car right now the junk yard said the will pull it or i can
keepingitbaker
Mar 1, 2013 01:24 PM
SirJohnIII
Nov 22, 2010 11:48 AM
xeromossyoak
Jan 10, 2008 08:56 PM
Calevra18
Sep 12, 2007 01:49 AM
Calevra18
